Plasron
Post by Plasron »
In Sheetcam, post processed, open Mach3, load the tap file, start G-code, the blasted thing starts drawing circles and not cutting the part.
Please HELP I’m pulling my hair out trying to figure out what I changed to cause this to happen.
Any help would be greatly appreciated
Ron
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
robertspark
Re: Sheetcam
Post by robertspark »
incremental or absolute mode?
check the config tab
Re: Sheetcam
You need to list your electronics and the post processor you are using, this is not a cookie cutter setup where one size fits all. Different interface boards require different post processors. If you have a parallel port BOB it is not the same as having USB BOB or ether connections.
A simple look at the number of post processors in SheetCam shows this.
Plasron
Re: Sheetcam
Post by Plasron »
acourtjester wrote: Fri Oct 04, 2019 2:24 pm You need to list your electronics and the post processor you are using, this is not a cookie cutter setup where one size fits all. Different interface boards require different post processors. If you have a parallel port BOB it is not the same as having USB BOB or ether connections.
Posted in my signature
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: Sheetcam
Post by Plasron »
Another quick question, is it in Sheetcam, Inkscape or Mach3, changing the Post Processor.
Ron
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: Sheetcam
Post by Plasron »
robertspark wrote: Fri Oct 04, 2019 2:22 pm incremental or absolute mode?
Absolute cords.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Sheetcam
the post processor is in SheetCam see attached screenshot and there is no Gorilla or Gecko post processor listed.
Maybe some other member will know which post processor you should be using.
Plasron
Re: Sheetcam
Post by Plasron »
acourtjester wrote: Fri Oct 04, 2019 7:30 pm the post processor is in SheetCam see attached screenshot and there is no Gorilla or Gecko post processor listed.
Thanks that’s what I was looking for.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Return to “SheetCam”
