Need Help Troubleshooting - Torch quit Arcing
Still a rookie at this entire process, but was cutting away successfully when the torch on the CNCquit arcing halfway through a cut. Cannot get the system to strike an arc since. I did put the hand held torch back on the plasma cutter and it worked great, but the CNC machine still won't go. Any advice is appreciated.
Re: Need Help Troubleshooting
more info needed. What type of plas are you using
-fitzy-
It ain't braggen if you can back it up!
What cnc machine, what plasma? Do you have torch height control?
Jim
Jim
Possably bad consumable, or bad ground
