Belt Sander
Maadman
Belt Sander
Post by Maadman »
I've heard you can use a wood belt sander to remove dross from metal. Anyone ever try it? Would love some info, so tired of flap disks!
Re: Belt Sander
Have you tried to use Muriatic acid and water 50/50 couple of hour dross gone. :lol:
Maadman
Re: Belt Sander
Post by Maadman »
Thanks for the suggestion. I sure have tried it I know it works very well for many people. It was good, but not that good. I also have a metal building, it doesn't like Muriatic acid at all! I do a lot of smaller text with tight curves that produces a lot of dross. It's what I like to do, and it sells well, so I am probably always destined to have a lot of dross. I know I have heard of people successfully using wood sanders for metal. Want to give it a try, and if anyone has any tips I would love to hear them.
CleanCutCreations
Re: Belt Sander
Post by CleanCutCreations »
Maadman wrote: Sun Sep 16, 2018 11:04 am Thanks for the suggestion. I sure have tried it I know it works very well for many people. It was good, but not that good. I also have a metal building, it doesn't like Muriatic acid at all! I do a lot of smaller text with tight curves that produces a lot of dross. It's what I like to do, and it sells well, so I am probably always destined to have a lot of dross. I know I have heard of people successfully using wood sanders for metal. Want to give it a try, and if anyone has any tips I would love to hear them.
I was thinking about trying that also. Did you ever try it?
Re: Belt Sander
Have you tried to knock the dross off with a small hammer, if you strike it at an angle it will break off most of the large dross. Just work around the part with the hammer. I then use a flap wheel to clean the rest off, but the acid dip is the easiest to do.
Maadman
Re: Belt Sander
Post by Maadman »
I've tried the hammer thing, not so hot on 14 gauge. I did try a wood sander, but it did not have a sensor to keep the sanding belt in position. That is not good! If we can keep the belt on track it works well.
