awkward file
paul j exeter
awkward file
Post by paul j exeter »
HI guys having some trouble with this file...when I reduce it to the correct size...525mm high I get all kinds of extra and overlapping lines etc....im using FASTCAM.... any help or advise greatly appreciated.
BanksAg
Re: awkward file
Post by BanksAg »
I'm not familiar with FASTCAM, but your file is a little weird. When I open it in Rhino 3D (our CAD program) or VCarve Pro (for our CNC router) the file looks fine, it's just really, really big (306,708 inches wide). Everything looks fine, just big. When I open it in Inkscape, it says there are 3 objects in a group, but nothing shows up even when I change line and fill visibility.
Are you using a 'scale' function to resize it? I've seen my kids try to drag things to size in various programs, and sometimes it does weird things. Or, they have accidentally scaled it in only 1 axis, or including the Z axis when they should have been working flat. When you scale it, it should keep the same perspective.
I scaled this to 525 mm tall in Rhino, and it looks good in Rhino & Inkscape, so hopefully this will work for you.
Tim Eggleston
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
paul j exeter
Re: awkward file
Hi Tim..many thanks for your help....file opened at right size but still had the overlapping lines and even some extra circles this time....I did the CAD COMPRESS function followed by a CAD CLEAN and ended up with about a third of the original lines remaining....I might be missing something in the process perhaps....
beefy
Re: awkward file
Post by beefy »
A few of the lines/nodes were messed up but I think it's good now.
Set it to 525 mm high.
RABBIT PATCH 1.dxf
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
paul j exeter
Re: awkward file
Thanks beefy....i really appreciate it...I will give it a try and let you know the outcome...you guys rock
paul j exeter
Re: awkward file
Hi I just tried the file ...looks all good to cut...however the actual size comes out at 240mm and when I try to expand to the cut size required it leaves lines and curves out of the part....just to be clear the 2 required cut sizes are 525mm and 288mm on the big letters R.... you have made better progress than I have so far......many thanks
sphurley
Re: awkward file
Post by sphurley »
525Rabbit.dxf
288Rabbit.dxf
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
paul j exeter
Re: awkward file
Hi Steve....thanks very much I will give it a crack ....I really appreciate your help
paul j exeter
Re: awkward file
Hi all....was all going well untill trying to generate the cutting code...error came up saying no entry on level 1....never encounted this before...any thoughts....thanks in advance
paul j exeter
Re: awkward file
Can anyone make this file cut ready ...I am unable to get this to generate a cut path worthy of using any materials....this thing is very frustarating...many thanks
sphurley
Re: awkward file
Post by sphurley »
Fastcam is the CAM software, what is your machine? Mach3?
Miller 350P
sphurley
Re: awkward file
Post by sphurley »
The only issue I see is the small h.
Miller 350P
paul j exeter
Re: awkward file
Hi Steve...thanks for your help.
Correct the cam software is FASTCAM which also generates the path file and cutting g code..
This is the first time i have had this issue
sphurley
Re: awkward file
Post by sphurley »
What gauge of metal? Where I see issues is the kerf width and overlapping. Might have to adjust the spacing between the letters and fix the h.
Let me know and I can try and tweak one.
Miller 350P
paul j exeter
Re: awkward file
HI Steve...cutting from 6mm steel
Really aprreciate your help
sphurley
Re: awkward file
Post by sphurley »
525RabbitV3.dxf
Try this one. There "should" be inside and outside cuts
Miller 350P
paul j exeter
Re: awkward file
Thanks again I am very grateful for your help...will advise outcome
paul j exeter
Re: awkward file
Hi Steve...worked perfect your a plasma lengend....thanks heaps awesome work
