Setting cut speed to 60% for holes
Mr. Fixit
Post by Mr. Fixit »
I know that poor hole cut quality has been discussed ad nauseum and I have tried to find a solution to my question, but couldn't. I have read numerous posts about angularity issues in holes, and holes that cut oval in lieu of round. I see that one suggestion is to cut the holes at 60% of the speed. I feel stupid, but I cant seem to find an option like that. :? How is this accomplished?
I have a TD Cutmaster 52. Currently cutting 1/8 CRS at 105 IPM, 40 Amps, 108 volts, 70 CFM. The main cuts are nice and square with virtually no dross. The holes are oval and irregular. The photos show that front and back
The holes that I am cutting are .500 and .125. I have set a .150 arc lead in, no lead out. Any suggestions are appreciated.
Holes Front.jpg (66.16 KiB) Viewed 1159 times
Oval Holes.jpg (69.86 KiB) Viewed 1159 times
4' x 4' DIY Table
CandCNC Bladerunner
Miller Vintage 250 Mig
Miller Syncro 180 Tig
Bridgeport 2J Mill - Fagor Dro
Southbend 14" x 40" EVS Lathe - Fagor Dro
Brook 18" Metal Shaper
Harig 612 Surface Grinder
steel 35
Re: Setting cut speed to 60% for holes
Post by steel 35 »
Path rules make sure somethings checked in the small dotted box, add a small lead out to get the torch away from you finished edge before stopping.
path rules.JPG (67.09 KiB) Viewed 1154 times
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Mr. Fixit
Post by Mr. Fixit »
Ah Ha, I get it. Do you suggest selecting On small Circles, Arcs, or Small Objects? Any harm in putting smaller than 1"?
Thank you,
4' x 4' DIY Table
CandCNC Bladerunner
steel 35
Post by steel 35 »
I have selected small circles less then 1.5" works well for me.
Try Perpendicular and arc lead ins see what works best.
Double check your gears and motors when powered up that everything's tight. You very well could have something a tiny bit loose. 1:30 -2:00 O'clock on the backside picture.
.5" hole = .250 lead in perpendicular is a good test (middle)
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Mr. Fixit
Post by Mr. Fixit »
Thanks for the insight. I will give that a go and report back. Thanks..
4' x 4' DIY Table
CandCNC Bladerunner
Mr. Fixit
Post by Mr. Fixit »
steel 35 wrote:I have selected small circles less then 1.5" works well for me.
Attached are the latest photos using a simple test of shapes. The round holes are .500. I have tested multiple settings and thus far this is the best. Very little angularity and dimensions are within .010 from front to back. In fact, the rounds are within .002 which amazed me. I guess I that I will have to go through this exercise with each thickness of material. Thank you for the lesson..
4' x 4' DIY Table
CandCNC Bladerunner
Mr. Fixit
Post by Mr. Fixit »
Oops, forgot the attachments.
Plasma Test Back.jpg (91.52 KiB) Viewed 1115 times
Plasma Test Front.jpg (81.69 KiB) Viewed 1115 times
4' x 4' DIY Table
CandCNC Bladerunner
