GM Corporate 14 Bolt drawings.
Here are a few Items for the 14 bolt I drew up. I have a few axle tabs, disc brake mounts, pinion guard, and full length truss also. Enjoy and fill free to improve on it and repost.
Messer MetalMaster Evolution
5-Axis Bevel-R Rotator
10'x25'
10'x25'
Re: GM Corporate 14 Bolt drawings.
awesome thanks for sharing
no problem! I am in the process of building a crawler so I have been drawing and cutting as I go. I should have a diff cover done this week also. I will post it here when I finish it.crosbike wrote:awesome thanks for sharing
10'x25'
10'x25'
Thanks, this will save me some time!
I got the diff cover drawn up yesterday. Once I get some final touches done I will post it up!
10'x25'
10'x25'
Here is a Diff Cover for the 14 bolt I have drawn up. I have not cut nor broke up to check how close it is, so it is not perfect and may require some trimming. I am hoping to get it cut and broke up tomorrow. Enjoy and let me know how it worked out if you get to it before I do.
10'x25'
10'x25'
are you still sharing the file?
Bad Links?
Sorry guys, I will post them up again when I get back to the house. I've been MIA for a bit. I have yet to burn them out and check the fit, if you get them burnt and broke up, let me know how they fit if you would!
10'x25'
10'x25'
EDIT! the two side left holes on the diff cover bolt pattern are off about half a hole too high. Make sure you correct before burning until I can get it re-uploaded.
**My drawings are for your personal use, please do not sell my designs.**
Ratboyracer
10'x25'
10'x25'
What angles would you bend it? 29 and 37?
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
thank you for creating and sharing
Thanks for sharing this. Was in the process of drawing this up
Amada CO2 3500 laser
Amada NT1303 CNC Press Brake
HAAS ST35Y
HAAS VF4SS
Solidworks CAD design
Tube Bending
Welding and Fabrication
HAAS ST35Y
HAAS VF4SS
Tube Bending
I cut out one of your 14 bolt covers and the two left bolt holes where off set about a half a hole, I slotted them out and made it work, everything else about them fit up really good. The two holes i mentioned should line up vertically with the two holes on the right. If i cut out another one in the future i will fix and repost it. Thanks op for the share.
Thanks for finding that! I will fix it and repost! I'm glad the rest of it fit up ok. Post a picture when you get it welded up!yroc fab wrote:I cut out one of your 14 bolt covers and the two left bolt holes where off set about a half a hole, I slotted them out and made it work, everything else about them fit up really good. The two holes i mentioned should line up vertically with the two holes on the right. If i cut out another one in the future i will fix and repost it. Thanks op for the share.
Ratboyracer
10'x25'
10'x25'
what is everyone using to bend that gauge ? just curious in the market to find correct break. Thanks in advance.
Look into a swag press brake kit. I have built many similar to what they sale just for pressing certain repeat items.DezertBlingMoto wrote:what is everyone using to bend that gauge ? just curious in the market to find correct break. Thanks in advance.
Best picture i got. Dont mind the crooked u bolt, that got fixed. Thread>https://www.rme4x4.com/threads/brians-b ... dd.114115/Ratboyracer wrote:Thanks for finding that! I will fix it and repost! I'm glad the rest of it fit up ok. Post a picture when you get it welded up!
Ratboyracer
Finally got it burnt and broke up. Fit together fairly nice but needs a little grinding depending how you want it placed on the ring. I used 3/8" HR.
10'x25'
10'x25'
10'x25'
10'x25'
thank you for the reply will definitely do so
Hey, thanks for the file. I'm having a problem opening the file. It keeps saying it's not a valid file format. I'm using Illustrator. Could be me, but thought I'd ask.
Thanks!!
Thanks!!
LDR Motionsystems 4x4 plasma
Hypertherm 45
Laser 4 X 4
Full woodshop
Hypertherm 45
Laser 4 X 4
Full woodshop
Hell yeah, thanks.
I'm having trouble opening all the files as well. im was trying to download the axle truss and diff cover. Can you please email me the files at r.arana13@yahoo.com please thanks.
Thanks for sharing a drawing that had to take a lot of your time and effort to complete. It opened fine with sheetcam for me.
Excellent work thank you.
