Bevel
rbmgf7
Bevel
Post by rbmgf7 »
I just redid my slats so I could bring the working piece closer to the water. I had a 4 inch deep pan but beforehand the part sat at least an inch above the water and kicked up terrible amounts of smoke and dust (but the cuts were great). I needed to cut down the dust so I remade the slats and now the part sits directly on top of the water.
I've cut 3/16 and 1/4 inch beautifully before with near neutral to the correct bevel and nearly no dross.
Now my parts are cutting as if the cut was leaning. There's a bevel on one side and the lower half is near neutral; as if the part is leaning.
The torch is square to the material and I have the correct cut direction in Sheetcam (programming-wise, I'm using the same speed and direction from before that yielded great results).
Not sure what caused this bevel "lean".
Equipment: PM45 with mech torch, ESS, Proma, Mach3, Sheetcam
rbmgf7
Re: Bevel
Post by rbmgf7 »
That was quick. I went back to troubleshoot some more.
Found one of the holes on the nozzle shield was plugged. Cleaned it out and now it cuts like normal.
ScottF
Re: Bevel
Post by ScottF »
Glad you got it sorted out quickly and it wasn't anything major.
WyoGreen
Re: Bevel
Post by WyoGreen »
Those plugged shield holes will bite you every once in a while. I've gotten to where I pop the torch off the mount and check the holes before every cutting session.
Router
Laser
