Good evening everyone. New to the forum & plasma cutting in general.
I have a 45xp mated to a Wright 5x10 table and could use some help with a cutting issue. I use Adobe Illustrator to create dxf files and the Sheetcam / Mach 3 the table came with. The issue is when cutting holes they're not centered in the piece. I've doubled & tripled checked the original vector file, and everything is centered.
The hole is shifted to the right almost a 1/16". What am I missing or doing wrong?
I'm not sure this would have been noticed on the original products we purchase the table for, but now we have picked up some flange / pipe bracket work and it's becoming an issue.
Any guidance is appreciated.
Holes Cutting Off Center
Re: Holes Cutting Off Center
Is the direction of the offset of the kerf always the same side of the part in relation to the position on the table? Is the topside of the hole centered to the part? Looks like you either have worn consumables or your torch is tilted in one direction and not square to the table. My machine is a LDR Motion 5 x 10 with a Hypertherm 65 Machine torch and have noticed in the past if the torch crashes it can shift the torch in the direction of the movement it was last traveling. I used a small framing square to check that the torch is square to the work piece in all directions. Not sure how to do this with a hand torch setup. After I made the adjustments I cut a square test piece and drew an arrow towards the back of the table so I could reference how it came off the table. This will show you which direction the adjustments need to be made if the issue is in your torch alignment. The bevel of the cut should be equal on all side and "tipped" toward the same surface, usually the top of the material depending on your cut height.
Jim Colt has some great pictures on this forum of what a proper cut should look like and what settings will best achieve those cuts. Im in NC and drove to Potsdam NY to pick up my table from LDR in June of this year. Dan offers a great machine and even better customer service and helped walk me through similar issues like what you are having.
Hope this helps.
Hope this helps.
Are the outside dimension correct for the part in the same direction. If not you have a steps per problem may just need the steps per calibrations redone.
The outside is supposed to be 2". When measuring on the front of the piece it measures 1 15/16" and when measured on the reverse side it is 1 31/32"
- WyoGreen
Some of your difference front to back is the bevel that a plasma torch makes when cutting. This is due to the taper of the plasma arc itself. If you are cutting slightly too high or too low, that will affect the taper. The torch cuts best on it's right side due to several factors. In other words, when doing an outside cut, the torch should go around the part in a clockwise direction. When doing an inside cut, the torch should be going the opposite direction.
So in your case, there may be several things to check. As acourtjester pointed out, you may need to check your steps per to ensure you are moving the exact distance commanded. Another thing may be the kerf width set in the Sheetcam tool table. If that figure is wider or narrower than the actual kerf width, then that could affect the finished cut size as well (Sheetcam adjusts the cut path based on the kerf width). And of course, the kerf width is also affected by the torch height above the material.
Those are my thoughts on the matter, hope some of it helps you track down your problem. Steve
Router
Laser
Router
Laser
Thanks acourtjester & Wyogreen. I'll be checking the steps and the kerf setting in Sheetcam.
I have worked through the kerf issue I was having, thank you. I'm still having a problem with square though. Steps have been adjusted and I'm getting equal measurements on all sides except when measured diagonally.
