Laser crosshair
Topics related to pen markers, remote controls, drawing tablets, & other plasma table related accessories
woodworker2001
Laser crosshair
Post by woodworker2001 »
Designed this for a laser crosshair for the table at the school I teach at. 3D printed and bought the two 5v line lasers from eBay. Haven't had a chance to get it wired to see how it works but clams up nice and seems like it will work.
sawdust1
Re: Laser crosshair
Post by sawdust1 »
How are you going to deal with the smoke and spatter of piercing?
home built 4x4 watertable. Qcad, SheetCam and Linuxcnc
Miller 375 Cutmate
Lincoln buzz box and a Miller Mig
KNK MAXX vinyl cutter
The adventure started with a Cricut cutter that I hacked.
_Ogre
Re: Laser crosshair
Post by _Ogre »
if you need thoughts on wiring the lasers to work with mach3 bladerunner read thru the laser x-hair link in my signature
i used an old pc power supply and one of the switched outputs on the bladerunner control box
Bobcat320
Re: Laser crosshair
Post by Bobcat320 »
My set up, all from eBay about $15. Uses AA battery pack
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
woodworker2001
Re: Laser crosshair
We shall see how it holds up to the sparks.
I appreciate the info on wiring. I am not running Mach 3 though. I just wired it to an old phone charger that puts out 5v. I have run it a couple times and seems like it should be ok.
Dana gear
Re: Laser crosshair
Post by Dana gear »
I don't know it there still available but we used a battery operated laser cross hair unit from Sears.
They were made for Sears drill presses , we fabricated a nylon bushing as the Sears unit had a slightly larger inside diameter then outside diameter of the plasma torch. 1.375"
It works great as the unit has its own clamp to choke it to the torch barrel. very easy on and off.
We simply cut lens covers from clear safety lens used in welding helmets to protect the laser, and attached with double sided tape.
The unit cost around 35 bucks from Sears. With the cross hairs powered up, a test pierce in 10 ga carbon was dead on as far as plasma accuracy would allow.
Return to “Pen Markers, Remote Controls, Drawing Tablets, etc.”
