So I've got my new base ready for the rails... Here's where I have to fix all of the warpage and poorly aligned joints that were welded by this kid I thought knew how to weld.
Question: If I bolt one raid side down and then just make sure the other one is equal distance apart at the ends and in the middle; that should ensure that the gantry bearings will run true right?! Why is it that when I do that, the diagonal measurement is still off by 1/4in. Does that "squaring" measurement really matter in this case? Not sure why this is bugging me, but I'd appreciate a reality check.
Am I overthinking this?
- Capstone
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Re: Am I overthinking this?
If the rails are the same length and diagonal measurements and the parallel measurements are correct that's as good as it gets.
I would be sure the parallel measurements are correct as that is the most important, a small difference of travel distance along an axis is not that big a deal.
Also make sure the rails are level with each other with no twist
- Capstone
Thanks. I think I covered all the angles. it's not "square" but the rails are definitely parallel and the same height and level. I just got the gantry back on the rails and it's running solid. The best part is how there's no shudder/vibration at the tip of the torch like before. The only problem is that I overshot the height of the gantry above the water table and have to make a correction in that aspect. Otherwise, I'm stoked to start making cuts.
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
stick a couple of wood 2X4 under the water table
- Capstone
I used the old shorter 2x2 rail supports from my previous table. They will work great.acourtjester wrote:stick a couple of wood 2X4 under the water table![]()
Now I just have to empty the old table and recover the slat holders. not looking forward to that mess.
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
