Anti-Collision_ Will this work?
RAD
Post by RAD »
Hi there, I've been trying to come up with a simple way of preventing torch collisions with 'tip-ups'
So I came up with the attached, it's a conductive plate that surrounds the torch tip, mounted to the torch holder separated by nylon spacers. An electrical wire comes from the conductive plate and one comes from the slats of the table, these two wires goes to the B.O.B as an E-STOP input, therefore as a tip-up makes contact with the conductive plate it closes the circuit an triggers the E-stop.
Will this work? or will I fry my Break-out Board because of the ground of the plasma cutter which is also connected to the slats?
Thanks in advance and apologies if this is a stupid idea :shock:
Re: Anti-Collision_ Will this work?
well since the ohmic touch uses a similar circuit that should work. but you will need more electronics you could use the Water switch that some are using for a ohmic switch. As long as the tip up metal will conduct with the slat better hookup may be directly on the cut metal plate
https://www.amazon.com/s/ref=nb_sb_noss ... %2FDc+M158
Post by tnbndr »
You're going to have a wire hooked to the torch plate that zooms around with the torch while cutting?!!! I would think tangling or the wire being cut would be a possibility.
A magnetic break away with a cut off switch would be much simpler.
RAD
Post by RAD »
Thanks guys,
Glad to hear I wont kill my B.O.B by trying this!
@tnbndr
I've drawn it in a simplified way just to illustrate my idea, actually the wire on the torch plate would be routed into the cable carrier with just enough 'slack' to allow for up & down movement of the torch. Also I might replace the nylon spacer with a metal spacer to avoid it melting, I was trying to insulate the torch plate from the torch mount/machine, hence the nylon spacer, this may not be necessary I guess?
one advantage of this over a magnetic breakaway is that the torch tip itself won't absorb any impact with tip ups, although you could make it so that the tip won't feel the impact, that might just add to complexity and I really want to keep it simple.
Another advantage is that the torch plate would shield sparks.
But I'm still open to opinions and ideas if this type of anti-collision still makes sense
East German
Post by East German »
Hallo
I have a magnet holder with switch. The switch makes the torch off and machine to pause.
At break of zero point remains
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
_Ogre
Post by _Ogre »
not sure how you'd see the torch for alignment and a partial tip up will still impact the torch shield
a mag base will stop damage to the torch from impacts
on thin metal and 250+ ipm feeds i'd think your idea will still crash
best way to avoid tip up impacts is to position your starts/stops where travel can't go over a tipped up part
sometimes traveling over a tip up is unavoidable this is where the mag base comes in handy
RAD
Post by RAD »
Thanks guys,
That makes sense, with crashes somthing has to give and it best be the mag letting loose from its base.
I read somwhere also with some tip ups the torch can actually move it out the way and continue cutting, not the case with my idea
Since my machine isn't up and running yet I have no experience with how often crashes may occur or how bad these crashes can be
Anyway I guess I should be looking for neodymium magnets now, any thoughts on what holding force and how many magnets I should be looking for?
East German
My System
Regards Peter
MyPlasmCNC
Machine Torch
Machine Torch
RAD
Post by RAD »
Thanks East German, nice system you got there. Think i'll use two 20mm diameter magnets since i'm using a hand torch and two dowels
_Ogre
Post by _Ogre »
not sure how dowel pins would break loose in a collision
you want the torch to break away in any x,y,z impact
most mag base break away mounts use ball ends or points that just barely mesh when lining up the torch
RAD
Post by RAD »
I plan on using the balls from a ball bearing and drill holes to match the dia. of the ball, press them halfway into the drilled holes and have semi drilled holes on the breakaway side
tnjind
Post by tnjind »
I used button head cap screws on mine, sorry no pics.
here is one I made using 3/8" balls and a 3/8" ball end-mill to make the recesses in the other plate.
Did not use a strong enough magnet it worked great but released to easy removed it. :(
You can buy different size balls at the hardware store.
