problem with new SheetCam update???
Any body having a problem with the new update 6.1.32
motoguy
Re: problem with new SheetCam update???
Post by motoguy »
What kind of issue?
I will not allow me to import this SVG file Or the original from a post here s few days ago. I get a black screen with a white line at a 45 degree angle.
GO AWAY VARMINT A2A.svg
(256.02 KiB) Downloaded 81 times
original posted SVG file
GO AWAY VARMINT.svg
(327.6 KiB) Downloaded 76 times
GO AWAY VARMINT.svg
Les Newell
Post by Les Newell »
It is not specific to the latest update. There is something about that drawing that neither the stable or development versions like. I will run some tests and see what I can find.
exapprentice
Post by exapprentice »
Hi Tom & Les
sounds like something similar to what happened to me earlier in the year see: http://www.plasmaspider.com/viewtopic.php?f=77&t=20093
but maybe not, I am sure Les will come back with his answer and sort it ;)
Best Regards to all
Exapprentice :D
(Pete)
Les Newell
I found the problem. There was an error in a matrix transformation so when that transformation was applied it totally trashed the coordinates. As far as I can see this bug only shows up if you have groups. It will be fixed in the next release.
Exapprentice, the drawing in the thread you linked is a different issue. It looks like the xml parser is throwing an error when it tries to read the file. I need to do more testing on this one as the xml parser isn't code I have ever looked at and it is pretty complex.
Thanks for the replies
Les this is the only file that it happens with, SheetCam works great for other files. I have contacted the OP to see what software he used to make the SVG drawing file. His other posted file in DXF worked fine with SheetCam.
I just happened in coincidence with the last release 6.1.32 but as I said nothing else has a problem.
Return to “SheetCam”
