Has any one had an issue with the tool set on hypertherm with a plunge rate. Sheet Cam
When I run a file through the post processor it runs the first few lines at plunge rate then jumps up or down to feed rate speed, I can manually change the plunge rate to feed rate and cure my problem, but what is the definition of plunge rate.???
Feed rate Issue
Re: Feed rate Issue
Plunge rate should be the feed rate when it drops from pierce height to cut height. What controller are you using?
