Pmax 65 1.125" Thick
Anyone tried this or have any advice on cutting 1 and an eighth thick carbon steel? Any help would be much appreciated. I would assume edge start for sure.
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
Gecko g540
Proma THC
Millermatic 211
- Capstone
Re: Pmax 65 1.125" Thick
I just recently cut .75 T1 steel with my PM45 with awesome results. BTW, that's a full .25inch thicker than the PM45 is rated for or 150% better... your PM65 should have enough power to push .125 past book limitations (only 12%) , especially since Hypertherm only rates to 80% of capacity.
Just use Hypertherm Book specs with good ground, clean dry air and brand new, fresh consumables.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
i have only cut to 1" with my pm65. basically edge start or drill a hole and set it at or extrapilated form book specs. i think the book stops at 1".
however remember your duty cycle i believe you can get to about 40" of cut before needing a rest. i recently had a job that needed 1300" of cut 1" material... i went a bought an oxy-fuel torch, might not be a bad option
tnttracy wrote:i have only cut to 1" with my pm65. basically edge start or drill a hole and set it at or extrapilated form book specs. i think the book stops at 1".
What he said. I run my at 8" per min with a .15 overcut on 1", I don't think you will have any problem depending on your cut length.
LDR 4x8 w scribe
Miller syncrowave 250
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
14"x9" plate.
Gecko g540
Proma THC
Millermatic 211
Gecko g540
Proma THC
Millermatic 211
I have cut 1.125 with my Torchmate and PM65 and it worked really well. As said above edge start or drill. During the test I cut at 65 amps, 6IPM and the water high in the pan. But for the actual job I cut at 8IPM and lowered the water about 1 inch below. Link below for facebook page video.
https://www.facebook.com/25283756822417 ... 156203779/
"Only two defining forces have ever offered to die for you; Jesus Christ and the American G. I. One died for your soul; the other for your freedom."
A good point brought up about the water. I bought a small water pump attached a hose that I use to run water on top of the metal. I was cutting 1"x10" wide material. The hose works good for keeping things cool and not moving on the table. The pump also works well for cutting tubing on the table as well.
LDR 4x8 w scribe
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Well today is the day, will post pics tomorrow of how it does. Right now I'll only be cutting one part and machining it for fit up.
Gecko g540
Proma THC
Millermatic 211
Gecko g540
Proma THC
Millermatic 211
Did pretty good I'd say.
Gecko g540
Proma THC
Millermatic 211
Gecko g540
Proma THC
Millermatic 211
- SeanP
Nice job!
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
That little Hypertherm did that? Nice Job!
Jim Colt Hypertherm
Jim Colt Hypertherm
Yessir, edge start at 8 ipm.
Gecko g540
Proma THC
Millermatic 211
Gecko g540
Proma THC
Millermatic 211
I always liked how the lower amp consumables work with thicker metal,, be it in a Esab,Victor or Hypertherm. 70 amps in the others. I have not cut 1.225 with my Hypertherm, but my friend does it with his 85.. Most cuts come out nice, but for true consistent cutting, he sticks with O/A
He will be doing fine, and then plasma issues show up, and he has to scrap the part.. That is why I have a 65 instead of a 85.. Smith machine O/A and O/P are my go to thick setup. At least I know you can go over 1.00 with the hyper on one or two cuts without issues.
Nice job too.
Nice job too.
