corner weld on water table 18 Ga.
Here is something that may help some. I finished the water table for my new table today it is 18 Ga just over 4X8 size. I paid a local sheet metal shop to bend it for me (great deal $20.). I had to weld the corners closed and this is how I did it. I cut a piece of copper tube to make a flat plate bend it to a 90 degree so I could clamp it on the corners as shown. I mig welded the inside then removed the copper and mig welded the outside edge. I ran a 1/2" tube dow each long top edge for support.
little blue choo
Re: corner weld on water table 18 Ga.
Post by little blue choo »
Good looking bead! Wish mine looked that smooth.
Rick
Rick
Arclight 9600 4x8 table
rons
Post by rons »
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Capstone
Post by Capstone »
ahhh... I see what you did there... pretty slick Rons. Took me a few times to figure it out...
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
little blue choo
That's a BAD idea Rons. I'll have to try it sometime.
Rick
Rick
motoguy
Post by motoguy »
Ha! I love this place.
NO matter what it is someone has a neat way to do things :) ;)
My problem would be when the caster go over the edge I would fall on the floor :lol: :lol:
