Fine Cut Settings
Fine Cut Settings
Hi all. I am wondering if there is anyone using a powermax 600 on a PCAM DHC machine. I am curious as to the settings that you are using for finecuts. I cut alot of 10, 12, 14 guage steel and am currently using regular consumables. Also what kerf offset are you using. Any help would be greatly appreciated. Thanks in advance.
Pete
Twisted Image Customs and Fabrication
Ontario Canada
Ontario Canada
Re: Fine Cut Settings
10 ga.
.5 second pierce delay, .062" cut height, .12" pierce height, 98 inches per minute, 40 Amps
12 ga.
.3 second pierce delay, ,062" cut height, .12" pierce height, 125 inches per minute, 40 amps
14 ga.
.25 second pierce delay, .062" cut height, 12" pierce height, 160 inches per minute, 35 amps
These specs will get you real close. If you get too much dross, increase the speed until it goes away. Cut height is critical.
For kerf offset....it is best to get the quality dialed in to where you want it...then do a straight line cut using those specs and measure the kerf. This is because anything that you change, speed, height, amperage, air pressure....will change the kerf width. Once you measure the kerf, divide it by 2, and enter that amount for your kerf width in the PlasmaCam setup files.
Jim Colt Hypertherm
12 ga.
14 ga.
Jim Colt Hypertherm
Hi Jim: Rod S in AZ, Does that work for the HT1250 with the DHC2? I am needing to cut some 1/8" alum 5052 and don't want to wast material. Any impute would be appreciated. Thanks' Rod Stevens.
Eagle Mountain Design & Decor
(If its worth doing Do it well)
Arizona
Arizona
Last edited by Eagle Mtn Metal Works on Mon Jan 24, 2011 10:58 am, edited 1 time in total.
Rod S in AZ
Hey Jim
are those numbers for fine cut tip
No....sorry, those specs are for the shielded 40 amp consumables for the Powermax600. The Fine cut setting are :
10 ga.
40 amps, cut height .08", pierce height .012", pierce delay .5 sec, cut speed, 50 ipm.
12 ga.
40 amps, cut height .08", pierce height .12", pierce delay .25 seconds, cut speed , 70 ipm.
14 ga.
40 amps, cut height .08", pierce height .12", pierce delay .2 seconds, cut speed 135 ipm.
These will be close with the 600, the 1000, the 1250 and the 1650 if using finecut consumables.
Jim
10 ga.
12 ga.
14 ga.
Jim
- FreeDXF.com
Jim,
Just wanted to say Thanks for sharing all your great knowledge regarding settings for this posters questions. It's nice to post a question and actually get a response from an expert like yourself. Keep up the great work! JH
Great technical advice for all the questions asked about Fine Cut Settings!! I am sure that it will be a great help to people in this field and it will be really something to keep in mind!! Information like this will go a long way to help each other to know more about stuff like this!!
