Sheetcam Tools
1badcad509
Sheetcam Tools
Post by 1badcad509 »
Ok I have lost my tool settings for my plasma. I found an old post that said they are available on the sheetcam download page. But that was an old post. Is there a place to get them? Thanks
Precision Plasma 5x10
Bladerunner Ethercut
Hypertherm 65
Miller Syncro 200
Hobart Iron Man 250
Enco Mill
Enco Lathe
Pro Tools Bender
Jet Combo Slip Roll Finger Brake Shear
Dayton 9x16 saw
Kool Koat Powder gun
80w laser cutter
Baleigh 4ft finger brake
Re: Sheetcam Tools
By lost them do you mean you do not see a box labeled TOOLs on the screen or the box has nothing in it.
Have you tried clicking on the file drop down and down at the bottom is load default tool sets. Or you can recreate them by clicking on the TOOLS drop down and redoing them there.
By the way SheetCam just sent out and new update so when you start SheetCam it will download it and run it on your system.
1badcad509
Re: Sheetcam Tools
No I had to reload due to a computer issue. So I don't have my original toolset. I have some that are just saying kerf size. I used to have the tools by thickness that was on my original setup.
Hypertherm 65
Miller Syncro 200
Hobart Iron Man 250
Enco Mill
Enco Lathe
Pro Tools Bender
Dayton 9x16 saw
80w laser cutter
SeanP
Re: Sheetcam Tools
Post by SeanP »
I you open a recent saved sheetcam job file, that should load the toolset you used for that job, then just save toolset as default.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Re: Sheetcam Tools
Post by tnbndr »
Can you search your old hard drive for a ".tools" file? That is your toolset file.
Once you are set up you should go to File/Save Toolset and save that file somewhere on a thumb drive etc for back up.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
_Ogre
Re: Sheetcam Tools
Post by _Ogre »
these are hypertherm toolsets for sheetcam
this forum won't let me upload .tools files
YOU WILL HAVE TO RENAME THE FILES BEFORE USING THEM
i renamed each file by adding .dxf to the end: HyperTherm-45_PlasmaTools.tools becomes HyperTherm-45_PlasmaTools.tools.dxf
you have to remove the .dxf on the end
they are massive 6k files :mrgreen:
littlefatbuddy
Re: Sheetcam Tools
Post by littlefatbuddy »
I had that happen and was able to go back to a date that everything was right and do a computer restore to a specified date. It worked perfectly.
Re: Sheetcam Tools
Post by tnbndr »
If you put them in a .zip file you can upload, but your way was quite creative.!!1
sphurley
Re: Sheetcam Tools
Post by sphurley »
They are on CandCNC download page Support files for Sheetcam, (all zipped up)
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Return to “SheetCam”
