Will a hypertherm 1000 cut half inch aluminum mechanized? I know it is only rated for half inch in steel.
Rob
half inch aluminum
Re: half inch aluminum
Sorry I didn't see this post sooner. Yes, the Hypertherm Powermax1000 will cut 1/2" aluminum. The recommendations listed in the operators manual say: 30 inches per minute optimum speed, 60 Amps, 1.5 second pierce time, and 1/16" torch standoff. You should use at least a 3/16" pierce height, then index down to 1/16" cut height. I suggest using mig welding anti spatter spray on the shield on the front of the torch to keep aluminum spatter from building up.
Jim Colt Hypertherm
Jim Colt Hypertherm
Jim,
Thanks for your reply, your involvment on this forum is why I chose hypertherm.The quality also was a factor.
Thanks again
Rob
Thanks again
Rob
