diving at end of cut
Minigunner1980
Post by Minigunner1980 »
hi guys I have a candcnc system with hyperthem powermax45 my torch head always seems to dive into the plate at the end of the cut is seems much more pronounced on thicker plate 3/8 im using mach3 and sheetcam any help would be great
thanks in advance
Re: diving at end of cut
Post by tcaudle »
Not enough info to help. Needs some model numbers and DTHC version You can get concise help on their support forum
WyoGreen
Post by WyoGreen »
As Tom mentions, if you go to the CandCNC forum, a search will find many answers to this question. I assume you are using SheetCam for your post processing, and I think you will probably need to make a Path Rule for the End of Cut that turns off your DTHC.
Router
Laser
